12603 Discussions
NIOS Error: Node instance "the_sopc_parameters_0" instantiates undefined entity "sopc
Hello
My project use the:
ACEX_1k_SOPC_Development_Board
Quartus ii 4.1
NIOS 3.1
i want to builder NIOS project,but show some error
Warning: OpenCore Plus time-limited core 6AFA_1001 may be used for hardware evaluation only
Error: Text Design File syntax error: Text Design File contains "'*'" where "ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE" was expected
Error: Node instance "the_sopc_parameters_0" instantiates undefined entity "sopc_parameters_0"
Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 11 warnings
Error: Processing ended: Wed Nov 13 13:15:48 2013
Error: Elapsed time: 00:00:06
my project
http://goo.gl/sy7jiw
The project only use nios processor
Would you please provide your Quartus project.Its look like there is some syntax error in your .vhd file.
Hello
My project use the:
Quartus ii 4.1
NIOS 3.1
Error: Text Design File syntax error: Text Design File contains '*', but must contain ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE
Error: Node instance the_sopc_parameters_0 instantiates undefined entity sopc_parameters_0
Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 118 warnings
Error: Processing ended: Wed Nov 13 14:07:37 2013
Error: Elapsed time: 00:00:47
my project
goo.gl/sY7jIW
Would you please provide design in .zip or .qar file of your Quartus project or .vhd or .v file in which you are getting the error.From the project description,it is difficult to provide you the solution.
Thank you for your help
My nios version is time limit edition
Yesterday,I found NIOS 3.2
After the installation NIOS 3.2 ,The project can build
