I am trying to load the NIOS code into EPCS and execute from EPCS. After compiling the code in Eclipse. I am getting the following error. address 0x3e09f88 of nios_hdmi.elf section `.text' is not within region `epcs_flash_controller_0' When I see the EPCS size it shows 2016 bytes. I have no idea how to increase the size of EPCS in Qsys. Can anyone help me on this? Thanks KarthikLink Copied
I don't recall there is an option to define EPCS size in Qsys. If you are executing-in-place from EPCS, very unlikely your .elf will exceed the EPCS size, unless your application is really huge, or your EPCS is relatively small.- Mark as New
You can't execute your code in place from the EPCS. The epcs_flash_controller_0 region is a ROM memory containing a bootloader that will copy your code from the EPCS into the main RAM. If you want to avoid that the only other solution I can think of is to implement an on-chip ROM in the FPGA but it will use resources.
