12599 Discussions
NIOS II 11.0--Error creating project
I am new to NIOS. I have build an SOPC system using Quartus 11.0. The system has an on-chip ram. Now, I am using NIOS II - Eclipse platform to build the application. I choose "New NIOS II Application and BSP from template". After adding my SOPC Information file, I selected blank project, but when I try to create the project, it gives the following error.
Quote:
SEVERE: [Error] altera_hal_linkerx_generator: Required linker section mappings do not exist: "[.entry, .exceptions, .rodata, .rwdata, .text, .bss, .heap, .stack]"
SEVERE: nios2-bsp-create-settings failed.
nios2-bsp: nios2-bsp-create-settings failed
nios2-bsp hal . D:/***.sopcinfo --cpu-name cpu failed
Can somebody help me with this? Is this error caused by some problem with my SOPC system or there is some other reason.
I am using NIOS II EDS 11.0.
Any response is highly appreciated.
I have the same problem...
Can anyone help us?
I'm using BeMicro SDK board and I have exactly same problem but I could not find a solution yet. Thanks.
Hi, when generating the BSP, try this:
in BSP editor-> liker script sheet assign linker region name to the desired sections. The .entry and .exception are set from SOPC/QSYS.
I hope that was helpful.
it works...
--- Quote Start ---
--- Quote End ---
Hey,
Can you please explain what do you mean by ".entry and .exception are set from sopc/qsys". When I am in BSP editor-> linker script Tab, I cannot select .entry and .exception options. Please let me know if I am doing something wrong or I am missing something.
Hi, exactly my point.
You can modify those field from SOPC/QSYS only.
https://www.alteraforum.com/forum/attachment.php?attachmentid=8394
