I am trying to run a very simple nios system with a timer and onchip memory with RTOS hello program using Quartus 11 and QSYS but the console shows nothing . I tried to run a hello world example but it doesn't work too. The console shows : Starting processor at address 0x000801B4 then nios II console shows nothing and neither does the command shell. The onchip memory reset vector address is 0x8000000 The system is attached and I am using a pll but it only multiplies by 1.Link Copied
I solved the problem by using an old project that used to work. I don't know what is the cause of this problem or when it happens.
