12603 Discussions
NIOS II Create Accumulator to assign data from PIOs?
Ok my cuestion is, I have one project created with the processor NIOS II standard, may i implement inside the same project an accumulator to asign data from the PIOs of the processor in less how i can insert a symbol (accumulator) in the same project NIOS II. :(:(:(
what you wanna do???
you can read pios and store to onchip ram....
--- Quote Start ---
--- Quote End ---
Read Pios and accumulate to add with a phase! and store in a LUT...
thats many ways to do that........... when i saw you can read pios and store to a onchip this is sof solution....
or you can do it in hardware..... do a vhdl acumulator and read by avalon mm
--- Quote Start ---
--- Quote End ---
or you can do it in hardware..... do a vhdl acumulator and read by avalon mm, yes this is a good option, but i need construct a cosine a sine signal and the best form for me its using a NIOS II processor, because the data is from a MATLAB GUI. :)
add to your vhdl block a spi interface to communicate to fpga...... and at sopc add a MM to read data from this block
http://www.alterawiki.com/wiki/spi_slave_to_avalon_mm
--- Quote Start ---
--- Quote End ---
ok this block its basically to communicate data betwen FPGA and NIOS II, thanks! :)
yes....
good luck
Franz Wagner
