Hi All,
We build SOPC as per demo document provided by Altera, then it is added to Quartus project, Compiled the corresponding and generated .sof, .sopcinfo and .ptf files are created successfully. After that opened eclipse from SOPC buider and clicked on -> New then "NIOS-II Application and BSP from template", after selecting corresponding .sopcinfo it is able to create test_bsp folder successfully (BSP folder) but it is not creating application test folder. But both the folders are generated when we execute using example sopc files. After if we create separately application folder using create new application and slecting corresponding bsp folder it is throwing error as "Undefined reference to Main" while building project in HAL -> alt_main.c file. Please help us to solve this issue. Thanks in advance, regards, sandeep Mail: sandeepk@uurmi.comLink Copied
which demo or example you are mentioning here?
