12603 Discussions
NIOS II GEN 2 Core Support for Intel Arria 10 Series FPGA
Chris039
Does NIOS II GEN 2 soft core processor to communicate to a host PC through 1G Ethernet for Intel Arria 10 Series FPGA?
Which core would be better? Economy or fast core.
What is the difference between economy and fast core package?
hareesh
sorry for late response.
Nios II can support 1G ethernet core
Chris039
thanks for the reply.
Can you share any documents about the support? I would like to know more details about 1G support.
Do you know that what is the difference between economy and fast core package?
hareesh
hareesh
Since I had provided you the solution/answer and did not received any feedback from you, I shall set this case to close pending. If you still need further assistance, you are welcome reopen this case within 20days or open a new case, some one will be right with you.
I shall set this case to close pending,
If you happened to close this case you will receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Thank you,
