12604 Discussions
NIOS II Gen2 linker script problem?
I tried to make a NIOS II Gen2 with a single on-chip ram
My flow is
qsys-edit
qsys-generate nios2g2.qsys --synthesis=verilog --simulation=verilog --output-directory=nios2g2
nios2-bsp HAL hal_bsp nios2g2.sopcinfo
nios2-app-generate-makefile --bsp-dir ./hal_bsp --src-files nios2_test.c
make
but I get the following message at the last make:
/altera/quartus/v14.0_web/nios2eds/bin/gnu/H-x86_64-pc-linux-gnu/bin/../lib/gcc/nios2-elf/4.7.3/../../../../../H-x86_64-pc-linux-gnu/nios2-elf/bin/ld: address 0x85d8 of nios2_test.elf section `.bss' is not within region `ram'
I first tried to put code into rom and data in ram, but ran into a similar problem, and went with a single ram since I would assume it was simpler.
The ram should be big enough:
grep memorySize nios2g2.qsys
<parameter name="memorySize" value="32768" />
Any idea's?
32k will only be big enough for the 'small' template examples.
Thanks! That was indeed the problem. The program I used was tiny, but I only used default values for the bsp generation so I did not get any of the small libc stuff etc. I increased the size and it's working now.
