Hi all,
I am using ther NIOS II IDE (19.1) on linux.
After building the project.elf I want to create also other files from the elf. How I can add the additional steps in build process or add a new build target wich is accepted from the build system.
It will also be helpfull if I have some documentation about this aspect of the NIOS II IDE.
Thank you in advance.
