NIOS II MPU initialisation
I am running a NIOS II/f core with MPU enabled. However NIOS doesnt seem to like it when I enable the MPU in software. I have followed the Altera MPU application notes and examples in setting up my data and instruction regions. The memory map is attached. I am using Limit for the region sizes. The number of regions is 8 for both data and instructions and minimum size is 4K.
My data and instruction region setup functions are below:
void nios2_mpu_data_init()
{Nios2MPURegion region[NIOS2_MPU_NUM_DATA_REGIONS];
unsigned int num_of_region = NIOS2_MPU_NUM_DATA_REGIONS;
/* DDR RAM memory region */
region[0].index = 0;
region[0].base = 0x10000; // Byte Address 0x10000000
region[0].mask = 0x20000; // Byte Address 0x20000000
region[0].c = 1;
region[0].perm = MPU_DATA_PERM_SUPER_RW_USER_RW;
/* System memory data region. */
region[1].index = 1;
region[1].base = 0; // Byte Address 0
region[1].mask = 0x40; // Byte Address 0x40000.
region[1].c = 1;
region[1].perm = MPU_DATA_PERM_SUPER_RW_USER_RW;
/* Debug RAM memory region */
region[2].index = 2;
region[2].base = 0x10C; // Byte Address 0x10C000
region[2].mask = 0x10E; // Byte Address 0x10E000
region[2].c = 1;
region[2].perm = MPU_DATA_PERM_SUPER_RW_USER_RW;
/* Audio RAM memory region */
region[3].index = 3;
region[3].base = 0x10E; // Byte Address 0x10E000
region[3].mask = 0x10F; // Byte Address 0x10F000
region[3].c = 1;
region[3].perm = MPU_DATA_PERM_SUPER_RW_USER_RW;
/* Host RAM memory region */
region[4].index = 4;
region[4].base = 0x10F; // Byte Address 0x10F000
region[4].mask = 0x110; // Byte Address 0x110000
region[4].c = 1;
region[4].perm = MPU_DATA_PERM_SUPER_RW_USER_RW;
unsigned int index;
unsigned int mask;
/* Rest of the regions are maximally sized and restrictive to supervisor/user. */
mask = 0x80000;
for (index = 5; index < num_of_region; index++){
region[index].base = 0x0;
region[index].index = index;
region[index].mask = mask;
region[index].c = 1;
region[index].perm = MPU_DATA_PERM_SUPER_NONE_USER_NONE; //No access for user and supervisor
nios2_mpu_load_region(region, num_of_region, 1);
void nios2_mpu_inst_init()
{unsigned int mask;
unsigned int num_of_region = NIOS2_MPU_NUM_INST_REGIONS;
Nios2MPURegion region[NIOS2_MPU_NUM_INST_REGIONS];
//Main instruction region.
region[0].base = 0; // Byte Address 0
region[0].mask = 0x40;
region[0].c = 0;
region[0].perm = MPU_INST_PERM_SUPER_EXEC_USER_EXEC;
mask = 0x80000;
unsigned int index;
for (index = 1; index < num_of_region; index++){
region[index].c = 0;
region[index].perm = MPU_INST_PERM_SUPER_NONE_USER_NONE; //No access for user and supervisor
nios2_mpu_load_region(region, NIOS2_MPU_NUM_INST_REGIONS, 0);
I have also added "flushp"s in the MPU load region function:
void nios2_mpu_load_region(nios2mpuregion region[], unsigned int num_of_region, unsigned int d)
{unsigned int region_num;
Nios2MPURegion current_region;
for(region_num = 0; region_num < num_of_region; region_num++){
current_region = region[region_num];
nios2_write_mpubase(current_region.base /*base*/, current_region.index /*index*/, d /*d*/);
asm volatile("flushp");
nios2_write_mpuacc(current_region.mask /*mask*/, current_region.c /*c*/, current_region.perm /*perm*/, 0 /*rd*/, 1 /*wr*/);
What am I doing wrong here?
Thanks in advance.
R
