NIOS II SBT quirk
Hi guys,
I was trying to use NIOS II SBT to create a NIOS II Application and BSP from Template. I selected the generic Simple Socket Example (rgmii) template.
So I clicked "finish".... and all that was generated in the project explorer column was only the BSP template, and no project. That is, if I generate an application from the hello world template, we only see helloworld_bsp and no helloworld.
Is this normal? And if not how should I fix this? This is a clean NIOSII installation by the way.
