12600 Discussions
NIOS II SOC SW Simulation Too Slow to be useful...
Has anyone seriously used simulation of a NIOS II SOC with SW to debug the design? Yes, I used AN351
to run and say "Hello World" in simulation but in a real full size SOC it takes forever to run.
I tried a very simple program that write to LED_PIO, and yes it runs, but it mostly accesses SDRAM.
What is needed is a NIOS II BFM that obeys the AVALON bus protocol but executes simple Read/Write (bus cycles)
instructions from a stimulus file. It does not run any 'C' SW!
Any suggestions?
You know there is an Avalon-MM master BFM that does exactly that right?
Thank you very much ! I did not know but I just found out that there is such a BFM and I am going through the tutorial... Thanks for your help!!!
