Hi, I am a student and I am doing my diploma work at the moment. It is about loading elf file on a NIOS II board - I have problems with the relocation that is done as part of the loading of an elf file - for instance I dont know the relocation types and what are the rules for relocation in each different relocation type - I suppose I need some special dosumentation which I am not able to find at this exact moment - Thank you in advance for your help!
Hi dimo,
> I have problems with the relocation that is done as part of the loading of an elf file What problems are you having? > for instance I dont know the relocation types If you use nios2-download, you don't need to know anything about elf relocation types. Or are you writing your own loader? > I suppose I need some special dosumentation which I am not able to find at this > exact moment Try: http://www.cs.princeton.edu/courses/archiv...reading/elf.pdf (http://www.cs.princeton.edu/courses/archive/fall05/cos217/reading/elf.pdf) Regards, --Scott- Mark as New
Hi, Scott - yes I am writing my own elf loader - the pdf that you sent me was my main source of information - My problem is that I dont know the rules that applies for the different reltypes in Nios Architecture.
Hi dimo,
> I dont know the rules that applies for the different reltypes in Nios Architecture. Sorry I can't be of more help here -- I'm not sure where you can get the details you're looking for ... other than by digging into the binutils code. Regards, --Scott- Mark as New
Hi dimo,
we developed our ELF bootloader with the exact same spec that Scott provided. Originally for a different soft-core but it works for NIOS II as well. Our loader relocates all sections with the type that has SHT_PROGBITS and SHF_ALLOC flag set. To save some space you can run your ELF trough strip first, but not required. Cheers, Roger- Mark as New
--- Quote Start --- originally posted by rsteiner@Feb 9 2006, 07:37 AM hi dimo,
we developed our elf bootloader with the exact same spec
that scott provided. originally for a different soft-core but
it works for nios ii as well.
our loader relocates all sections with the type that has sht_progbits
and shf_alloc flag set.
to save some space you can run your elf trough strip first,
but not required.
cheers, roger
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12655)
--- quote end ---
--- Quote End --- http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
