NIOS II sim with Questa
Majo
Hi!
I'm trying to start a simulation of my NIOS design but when I launch Questa from Eclipse tool I see a such error
As a result, my code doesn't executed as I expect.
Could anyone assume what's wrong?
Majo
In additional, I've found a such information https://www.intel.com/content/www/us/en/docs/programmable/683820/current/nios-ii-sbt-makefile-mem-init-generate.html :
The main question, why Eclipse doesn't generate it.
EBERLAZARE_I_Intel
Which version are you using?
Majo
I use these tools:
Eclipse Mars.2 Release (4.5.2);
Quartus Prime 21.1.1 Build 850 Lite Edition;
Questa - Intel FPGA Starter Edition.
EBERLAZARE_I_Intel
Did you run into any issue in eclipse when building your project?
Could you share your design for me to replicate and check?
Majo
Yes of course, you could find my project as an attached file. Its very simple project.
EBERLAZARE_I_Intel
Thanks, let me try to do the simple replication, you may expect some delay in my response latest by Monday next week.
EBERLAZARE_I_Intel
I just noticed, the .dat file seems to be in your project folder same as your .sopcinfo file.
You might need to move the the .dat file to the directory that is reporting the error or edit your script/makefile in Questasim to search the .dat file location.
Majo
Thank you for your help. It was a stupid mistake from my side.
Majo
But by the way, its still doesn't work. I've done a similar *.dat file before. It always includes the same data.  At my simple design I want to see a meander signal instead that I see only low level.
EBERLAZARE_I_Intel
Apologies for the late respond, are you still seeing the initial error shown in the first screenshot?
So using the new .dat is the same as using a .dat from previous builds?
I recommend that your question should be file on a new ticket topic on Questasim.
EBERLAZARE_I_Intel
Do you have any update?
Majo
There is no update at all. I think the main issue its Eclipse software because it doesn't generate *.bat file or other files are necessary for a simulation process.
EBERLAZARE_I_Intel
I am not familiar with Questa, we do not offcialiy support Nios II simulation using Questa sim, might meed to use modelsim:
https://www.intel.com/content/www/us/en/docs/programmable/683282/current/running-a-nios-ii-system-with-modelsim.html
There is Nios V using Questa sim, but Nios V currently only supported for Quartus pro versions and 10 series board:
https://www.intel.com/content/www/us/en/docs/programmable/726952/22-1-21-2-0/simulating-processor-designs.html
EBERLAZARE_I_Intel
Have you try with Modelsim?
EBERLAZARE_I_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
