Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
NIOS II - srec file
How create srec file for NIOS II application? From elf file or other? How?
Thank you for help
Highlighted
Hi leszekd,
Use objcopy and tell it to generate S-Record output, e.g.:
$ nios2-elf-objcopy -O srec myapp.elf myapp.srec
--Scott
Highlighted
Thank you, smcnutt!
