12600 Discussions
NIOS SRAM memory corruption check
sRama28
hi intel
need answer for below.
1.how to find heap and stack starting and ending address. heap_start and stack base adress are same in objectdumb file .is it right?
2.how to check stack growing and corrupting program lines in SRAM .suggest any memory corruption check method?
3.if i created RTOS task after the task execution stack pointer is pointing bss section of code .is it right behavior or sp always within the limit of stack memory?
4.if i added any breakpoints code behavior is changing getting failure in ethernet driver files what is the reason?
sRama28
any update on this intel guys ..
EricMunYew_C_Intel
May I know which document you followed?
EricMunYew_C_Intel
You can run a Nios simulation to find the sp and heap locations and for monitoring.
You can allocate your program and stack in different memory regions.
The sp should be within the limit of stack memory.
Your code should not be changing by adding breakpoints.
