12469 Discussions
NIOS Serial Communication through JTAG UART
MWang36
I am currently trying to establish the serial communication between NIOS II and Host PC through JTAG UART. I found some material talked about using nois2-terminal command.
Is there anyone can share some material about how to write C programs and configure the SOPC?
Abe
Valued Contributor II
Ahmed_H_Intel1
Also you can use the RS232 to communicate with a PC
here is a working RS232 project for writing and reading with RS232 (UART) (Using DE0-Nano-SoC), you are free to change the board but check the pin planner to be compatible with the new board.
