Nios® II Embedded Design Suite (EDS)
Support for Embedded Development Tools, Processors (SoCs and Nios® II processor), Embedded Development Suites (EDSs), Boot and Configuration, Operating Systems, C and C++
NIOS - Test DM9000
I can not run DM9000 module after many tries on my DE2-70 board and wolud like to test sample project file from http://www.alterawiki.com/wiki/tryoutuclinux.
This is how looks like boot process:
nios2-download -g ZImage_DE2_70_NIOS_HOST_MOUSE_VGA_v1.1
Using cable "USB-Blaster [USB 1-1.1.1]", device 1, instance 0x00
Pausing target processor: OK
Initializing CPU cache (if present)
OK
Downloaded 1208KB in 6.4s (188.7KB/s)
Verified OK
Starting processor at address 0x04500000
nios2-terminal
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB 1-1.1.1]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Uncompressing Linux... Ok, booting the kernel.
Linux version 2.6.19-uc1-g7e2efdd1-dirty (thomas@darkstar.wytron.com.tw) (gcc version 3.4.6)# 4 PREEMPT Wed Mar 12 10:16:04 CST 2008
uClinux/Nios II
Altera Nios II support (C) 2004 Microtronix Datacom Ltd.
setup_arch: No persistant network settings signature at 08FF0000
Built 1 zonelists. Total pages: 8128
Kernel command line:
PID hash table entries: 128 (order: 7, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory available: 30304k/32768k RAM, 0k/0k ROM (1473k kernel code, 694k data)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
io scheduler noop registered
io scheduler deadline registered (default)
Serial: JTAG UART driver $Revision: 1.3 $
ttyJ0 at MMIO 0x896091e8 (irq = 2) is a jtag_uart
dm9000 Ethernet Driver
dm9000: read wrong id 0xffffffff
dm9000: wrong id: 0xffffffff
dm9000: not found (0).
TCP cubic registered
NET: Registered protocol family 17
Freeing unused kernel memory: 576k freed (0x417e000 - 0x420d000)
Shell invoked to run file: /etc/rc
Command: hostname uClinux
Command: mount -t proc proc /proc
Command: mount -t sysfs sysfs /sys
Command: mount -t usbfs none /proc/bus/usb
mount: Mounting none on /proc/bus/usb failed: No such file or directory
Command: mkdir /var/tmp
Command: mkdir /var/log
Command: mkdir /var/run
Command: mkdir /var/lock
Command: mkdir /var/empty
Command: ifconfig lo 127.0.0.1
Command: route add -net 127.0.0.0 netmask 255.0.0.0 lo
Command: cat /etc/motd
Welcome to
____ _ _
/ __| ||_|
_ _| | | | _ ____ _ _ _ _
| | | | | | || | _ \| | | |\ \/ /
| |_| | |__| || | | | | |_| |/
| ___\____|_||_|_| |_|\____|\_/\_/
|_|
For further information check:
http://www.uclinux.org/
Execution Finished, Exiting
Sash command shell (version 1.1.1)
And I have here dm9000: not found (0).
There is something wrong with my board are with this image?
Finally I run the dm9000 on DE2-70. There is a difference beetwen DE2 and DE2-70 with dm9000. Have to change in dm9000 component timing setting and set good 25MHz clock.
