I am currently running the NIOS 2 GEN 2 simulation in Modelsim, i would like to know when the NIOS 2 GEN 2 CPU is going to the ready mode to accept the command, can you point out where to get this signal? thanks. regards, KOk SHyang.Link Copied
What do you mean by ready mode and accept the command?
Usually, you can just write C codes for your Nios II application. You can start off with the hello world as your template.
