Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
NIOSII Altera Monitor C code help!!!
typedef volatile struct
uint32_t period;
uint32_t pulse_width;
} PWM;
voidmain(void){ pwm * const pled = ...
pled->period = 5; pled->pulse_width = 4;
asm("nop"); asm("nop"); asm("nop"); pled->pulse_width = 2;}
For the code above.
I would like to know what modules I need to create for the computer. For example if i need, a PIO module in SOPC called pLED or period or pulse_width or all of them.
