Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Need help implementing IDE controller
I am using a Stratix professional edition board with a niosII processor. I am trying to build an IDE interface to the J16 pins, using the ata(OCIDEC 3) core from opencores. I have used the interface to user logic in SOPC with the ata core, and I have selected the OCIDEC support when i configured the kernel.
I get an error, when i build the kernel:
error: `na_ide_ide' undeclared (first use in this function)[/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/ide/ide.c]
To get rid of this error, i included the compact flash in the SOPC builder, and it compiles, but now the compact flash is all that is being read, the hard drive that i connect to J16 pins is not.
Does anyone have any ideas?
Deepti
