Hi, so I'm just a newbie and I plan to use the SD card of my Altera DE2 board for a project. I managed to find the example that comes with the CD named as DE2_SD_Card_Audio. So I saw that there's a header file named "SD_Card.h". I understand this is the one responsible for reading files that's inside the SD Card. Can someone help me understand the codes in this header file?
#ifndef __SD_Card_H__
# define __SD_Card_H__
// SD Card Set I/O Direction
# define SD_CMD_IN IOWR(SD_CMD_BASE, 1, 0)
# define SD_CMD_OUT IOWR(SD_CMD_BASE, 1, 1)
# define SD_DAT_IN IOWR(SD_DAT_BASE, 1, 0)
# define SD_DAT_OUT IOWR(SD_DAT_BASE, 1, 1)
// SD Card Output High/Low
# define SD_CMD_LOW IOWR(SD_CMD_BASE, 0, 0)
# define SD_CMD_HIGH IOWR(SD_CMD_BASE, 0, 1)
# define SD_DAT_LOW IOWR(SD_DAT_BASE, 0, 0)
# define SD_DAT_HIGH IOWR(SD_DAT_BASE, 0, 1)
# define SD_CLK_LOW IOWR(SD_CLK_BASE, 0, 0)
# define SD_CLK_HIGH IOWR(SD_CLK_BASE, 0, 1)
// SD Card Input Read
# define SD_TEST_CMD IORD(SD_CMD_BASE, 0)
# define SD_TEST_DAT IORD(SD_DAT_BASE, 0)
# define BYTE unsigned char
# define UINT16 unsigned int
# define UINT32 unsigned long
void Ncr(void);
void Ncc(void);
BYTE response_R(BYTE);
BYTE send_cmd(BYTE *);
BYTE SD_read_lba(BYTE *,UINT32,UINT32);
BYTE SD_card_init(void);
BYTE read_status;
BYTE response_buffer;
BYTE RCA;
BYTE cmd_buffer;
const BYTE cmd0 = {0x40,0x00,0x00,0x00,0x00};
const BYTE cmd55 = {0x77,0x00,0x00,0x00,0x00};
const BYTE cmd2 = {0x42,0x00,0x00,0x00,0x00};
const BYTE cmd3 = {0x43,0x00,0x00,0x00,0x00};
const BYTE cmd7 = {0x47,0x00,0x00,0x00,0x00};
const BYTE cmd9 = {0x49,0x00,0x00,0x00,0x00};
const BYTE cmd16 = {0x50,0x00,0x00,0x02,0x00};
const BYTE cmd17 = {0x51,0x00,0x00,0x00,0x00};
const BYTE acmd6 = {0x46,0x00,0x00,0x00,0x02};
const BYTE acmd41 = {0x69,0x0f,0xf0,0x00,0x00};
const BYTE acmd51 = {0x73,0x00,0x00,0x00,0x00};
void Ncr(void)
SD_CMD_IN;
SD_CLK_LOW;
SD_CLK_HIGH;
SD_CLK_LOW;
SD_CLK_HIGH;
void Ncc(void)
int i;
for(i=0;i<8;i++)
SD_CLK_LOW;
SD_CLK_HIGH;
BYTE x,y;
SD_CMD_OUT;
SD_DAT_IN;
SD_CLK_HIGH;
SD_CMD_HIGH;
SD_DAT_LOW;
read_status=0;
for(x=0;x<40;x++)
Ncr();
for(x=0;x<5;x++)
cmd_buffer=cmd0;
y = send_cmd(cmd_buffer);
do
for(x=0;x<40;x++);
Ncc();
for(x=0;x<5;x++)
cmd_buffer=cmd55;
Ncr();
if(response_R(1)>1) //response too long or crc error
return 1;
Ncc();
for(x=0;x<5;x++)
cmd_buffer=acmd41;
Ncr();
} while(response_R(3)==1);
Ncc();
for(x=0;x<5;x++)
cmd_buffer=cmd2;
Ncr();
if(response_R(2)>1)
return 1;
Ncc();
for(x=0;x<5;x++)
cmd_buffer=cmd3;
Ncr();
if(response_R(6)>1)
return 1;
RCA=response_buffer;
Ncc();
for(x=0;x<5;x++)
cmd_buffer=cmd9;
cmd_buffer = RCA;
cmd_buffer = RCA;
Ncr();
if(response_R(2)>1)
return 1;
Ncc();
for(x=0;x<5;x++)
cmd_buffer=cmd7;
cmd_buffer = RCA;
cmd_buffer = RCA;
Ncr();
if(response_R(1)>1)
return 1;
Ncc();
for(x=0;x<5;x++)
cmd_buffer=cmd16;
Ncr();
if(response_R(1)>1)
return 1;
read_status =1; //sd card ready
return 0;
BYTE SD_read_lba(BYTE *buff,UINT32 lba,UINT32 seccnt)
BYTE c=0;
UINT32 i,j;
lba+=101;
for(j=0;j<seccnt;j++)
Ncc();
cmd_buffer = cmd17;
cmd_buffer = (lba>>15)&0xff;
cmd_buffer = (lba>>7)&0xff;
cmd_buffer = (lba<<1)&0xff;
cmd_buffer = 0;
lba++;
Ncr();
while(1)
SD_CLK_LOW;
SD_CLK_HIGH;
if(!(SD_TEST_DAT))
break;
for(i=0;i<512;i++)
BYTE j;
for(j=0;j<8;j++)
SD_CLK_LOW;
SD_CLK_HIGH;
c <<= 1;
if(SD_TEST_DAT)
c |= 0x01;
*buff=c;
buff++;
for(i=0; i<16; i++)
SD_CLK_LOW;
SD_CLK_HIGH;
read_status = 1; //SD data next in
return 0;
BYTE response_R(BYTE s)
BYTE a=0,b=0,c=0,r=0,crc=0;
BYTE i,j=6,k;
while(1)
SD_CLK_LOW;
SD_CLK_HIGH;
if(!(SD_TEST_CMD))
break;
if(crc++ >100)
return 2;
crc =0;
if(s == 2)
j = 17;
for(k=0; k<j; k++)
c = 0;
if(k > 0) //for crc culcar
b = response_buffer;
for(i=0; i<8; i++)
SD_CLK_LOW;
if(a > 0)
c <<= 1;
else
i++;
a++;
SD_CLK_HIGH;
if(SD_TEST_CMD)
c |= 0x01;
if(k > 0)
crc <<= 1;
if((crc ^ b) & 0x80)
crc ^= 0x09;
b <<= 1;
crc &= 0x7f;
if(s==3)
if( k==1 &&(!(c&0x80)))
r=1;
response_buffer = c;
if(s==1 || s==6)
if(c != ((crc<<1)+1))
r=2;
return r;
BYTE send_cmd(BYTE *in)
int i,j;
BYTE b,crc=0;
SD_CMD_OUT;
for(i=0; i < 5; i++)
b = in;
for(j=0; j<8; j++)
SD_CLK_LOW;
if(b&0x80)
SD_CMD_HIGH;
else
SD_CMD_LOW;
crc <<= 1;
SD_CLK_HIGH;
crc ^= 0x09;
b<<=1;
crc &= 0x7f;
crc =((crc<<1)|0x01);
b = crc;
for(j=0; j<8; j++)
SD_CLK_LOW;
if(crc&0x80)
SD_CMD_HIGH;
else
SD_CMD_LOW;
SD_CLK_HIGH;
crc<<=1;
return b;
# endif
