Hi Folks,
I'm just trying to get Quartus 16.0 (Also tried 15.1) running on my 64 bit Ubuntu Xenial 16.04 machine. I've fixed the permission/udev errors etc and can 'see' the USB Blaster....unfortunately that's as far as I get. If I try to program it times out, and if I try to probe the chain it doesn't like it; dmarples@steal:~/bin/altera_lite/16.0/quartus/bin$ sudo ./jtagconfig 1) USB-Blaster [2-1.3.1.1.4] Unable to read device chain - JTAG chain broken I've tried two different boards, two different USB Blasters and two different cables, in many combinations. I've also tried USB2 and USB3 ports. I'm reasonably sure it's a software problem exacerbated by my lack of capability, so any help or advice would be greatly appreciated. DAVELink Copied
OK, I'd best post the resolution to this in case someone else bumps into it. I don't lay claim to have fixed it myself, onto to have applied a little more Google-fu. The solution was actually from https://www-acc.gsi.de/wiki/timing/quartusinstallubuntu1404. Just in case that page ever disappears, it seems that the problem is due to a missing 32 bit libudev, fixed with;
$ sudo apt-get install libudev1:i386
$ sudo ln -sf /lib/x86_64-linux-gnu/libudev.so.1 /lib/x86_64-linux-gnu/libudev.so.0
After this you'll need to rebuild your libs, or just reboot...then, at least in my case, all was good; dmarples@steal:~/bin/altera_lite/16.0/quartus/bin$ ./jtagconfig
1) USB-Blaster
020F10DD EP3C(10|5)/EP4CE(10|6)
DAVE
Thanks a lot for this, I was banging my head to the wall for months to solve this, thought it was an USB3/USB2 incompatibility and tried everything, from cable length to USB hubs to forcing USB speed on the bus! Can confirm this works in Ubuntu 16.10 too :-D
...spoke too soon... it works sometimes with SOFs and never with POFs in linux... but it works always in Win7 running in a VirtualBox VM...
