12600 Discussions
NicheStack - changing IP address without rebooting
is there a way of changing IP address of the Nios2 without rebooting the whole Nios?
Looking through the sources of iniche I can see there is only a alt_iniche_init() procedure, but nothing for shutting it down or re-starting it...
So far I have tried something like
tse_mac_close(0); delete_network_tasks(); netmain(); create_network_tasks();
but instead of closing and reopening the same interface, it "discovers" a 2nd interface
.................................... prep_tse_mac 0 Your Ethernet MAC address is 00:07:35:04:b2:77 Static IP Address is 172.16.100.81 prepped 1 interface, initializing... .................................... iniche restart triggered... Deleting network tasks...DONE InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 1 Your Ethernet MAC address is 00:07:35:04:b2:77 Static IP Address is 172.16.100.64 prepped 2 interfaces, initializing... ....................................
Thanks!
I believe you're looking for ni_set_config(). See net.h and iface.c in the iniche files.
/* FUNCTION: ni_set_config() * * set IP address and subnet for a particular device. * * PARAM1: NET ifp * PARAM2: struct niconfig_0 * cfg * * RETURNS: 0 */
Thanks, that worked nicely (and seems safer than this solution (http://www.alteraforum.com/forum/showthread.php?t=24101)).
Hi there,
I'm reviving this thread with a follow-up question:
is it possible to change the mac address on the fly in nichestack?
I didn't consider this need at start, but yesterday I configured on a system a MAC address (possibly a reserved group) and subsequently was unable to access it via switched network.
--- Quote Start ---
--- Quote End ---
the proposed solution worked just fine until I realized I need the possibility to change the gateway as well. Are you aware of any such function to allow me that?
You probably need to write your own function to do that, as it doesn't look like there is one around already.
