Nios 2 Boot Issue
JLee25
I am using Cyclone 10 GX for an embedded project with Nios 2.
Quartus Pro 19.2 + C 10 GX + MT25QU256
For unknown reason, the Nios 2 did not boot.
I have to manually download the elf again through JTAG..
Setting in Qsys,
Linker,
Memory map,
BRs,
Johnson
EricMunYew_C_Intel
Hi, Johnson
Can we close this ? you may open a new one if you still have inquiry and want to follow up.
Eric
JLee25
Hi Eric,
  I am trying to use the information provided in AN458 with Arrow support.
I will let you know if I need any assistant from you.
Thank you!
BRs,
Johnson
EricMunYew_C_Intel
Hi, Johnson
Eric
JLee25
Hi Eric,
  Yes!
Thank you!
BRs,
Johnson
EricMunYew_C_Intel
Thanks Johnson.
