Hi gang.
I am using the altera avalon i2c driver for communication to peripheral devices on my board.
I want to read from different i2c addresses to determine if a device is present.
For instance a small code snippet:
Well, solved this issue, but I did not like editing the intel avalon driver.
on line 581 of the driver I changed retry from 100000 to 100.
This times out in about 10 seconds. i think 100000 is just way too many and takes forever.
Now the problem is that I need to read some registers beyond 0xFF.
I need to read registers 0x149 and a few other register addresses higher than that. It seems the driver ALSO limits this even though the register variable passed into i2c_read_reg is an alt_u16.
So this is my real question.....how to read registers past 0xFF. I can read up until there, but once I try 0x100 there are errors.
Hi Jacob
The feature that you are looking for is the i2c probe.
Unfortunately the library does not support this feature.
As for the addressing, did you change the addressing mode from 7Bit to 10Bit addressing?
You could search for "ALT_AVALON_I2C_ADDR_MODE_10_BIT "
Jingyang, Teh
Good morning Jingyang,
I tried this but so far no success. Actually now I cannot read anything at all.
I think the issue is that my devices have normal, 7/8 bit addresses. 0x57, for example. But the registers that I need to read in these devices are anywhere from 0x000 to 0x145.
with address mode at default(7 bit), I can read any registers from 0x00 to 0xFF at address 0x57.
By using the below code to try and set 10 bit addressing, I lose the ability to read everything. It just returns with a NACK error.
is it possible with this driver to have 7 bit addresses, but 10 bit registers??
I have this code now for configuration. Is this the correct way to do this??
I have managed to find in the i2c driver from intel (i2c_interface.c) the following code inside the i2c_read_reg function:
So there is at least some attempt to control the tx buffer when the value of the register is greater than 0xFF.
This TX buffer is sent to the function
Were there any updates on this issue?
Jacob
Hi Jacob
Sorry that I have suggested you to change the addressing mode from 7 to 10bit.
I misunderstood that your addressing is greater than 7 Bit.
For the register address in the device, if it is greater that FF, then you would need to send another extra byte for the register address.
It is normal in this case, because all data send in the i2c bus are byte size.
In your case if you would like to read a register address greater than 0xFF then you would need to send a total of 3 bytes to initiate the read.
e.g.
<device address byte> <register address byte 1> <register address byte 2> ... <remaining bytes>
Could you share the datasheet of the device that you are trying to read from?
Jingyang, Teh
Hello Jingyang,
I understand this point. However, in the driver provided by Intel there is already functionality for this that seems to not function. See the code snippet i posted above:
Hi Jacob
Could you share me the github link to i2c_interface.c that you are referring too?
Are you using the "i2c_interface.c" or the" alt_avalon_i2c.c"?
From the "alt_avalon_i2c_master_tx_rx" function you need to enter the register as part of the buffer.
The "alt_avalon_i2c_master_transmit" will loop through the buffer to transmit the whole array.
I do not see a problem in this implementation.
Jingyang, Teh
Hello Jingyang.
Sorry, we have been closed for the Christmas break so I am only seeing your response today.
I agree this should work fine since the buffer holds the entire register address and loops through the whole buffer. But it is not working for whatever reason.
The i2c_interface.c is provided to us as confidential from Intel so I cannot publicly share that. Maybe you can poke around at Intel and find it.
I cannot find any flaw in this implementation. I will check again the datasheets of the hardware to make sure I am not missing something.
Jacob
Hi
Any update on this case?
Jingyang, Teh
Hi
Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
