Hello, I try make sof file with elf according to this youtube manual. https://www.youtube.com/watch?v=jofaxly-rue
I have problem, during compilation. Please how do I solve? :( Please see jpg pictureLink Copied
You've split the parameter value in two lines. Try to remove carriage return in the parameter assignation.- Mark as New
--- Quote Start --- Hello, You've split the parameter value in two lines. Try to remove carriage return in the parameter assignation. --- Quote End --- Yes, but this did Quartus. I tried rewrite but quartus still see error.
The same error ... i.e. at the location of parameter init_file = ... ?
Can you attach screenshot- Mark as New
Did you try a file name without blank?
