Hi All,
After I boot from an epcs device the chip select remains asserted (control register = 0x0000_0400). Has anyone else observed this? --Scott BTW: This causes the u-boot epcs command to fail the first time it is invoked.Link Copied
Yes, see this topic - look for the post from Kero Kero for a workaround:
http://www.niosforum.com/forum/index.php?a...ct=st&f=2&t=850 (http://www.niosforum.com/forum/index.php?act=st&f=2&t=850)- Mark as New
Thanks Jesse ...
... in general, it's probably good practice from a software point-of-view to assume that the chip select was left in an inappropriate initial state ... ... so it's time for me to use good practice ;-) Thanks again, --Scott- Mark as New
Just an FYI for anyone following this thread:
A jump to the reset address (soft reset) when booting from the epcs_controller will cause the epcs boot loader to hang. Prior to doing something like this, you must make sure theepcs chip select is negated. Regards, --Scott
