Nios II Building Error
I got this error when building a Nios II project. Please help me fix it. :)
alt_sys_init.c:(.text+0x8): warning: Error: Interrupt not connected for JTAG_UART. You have selected the interrupt driven version of the ALTERA Avalon JTAG UART driver, but the interrupt is not connected for this device. You can select a polled mode driver by checking the 'small driver' option in the HAL configuration window, or by using the -DALTERA_AVALON_JTAG_UART_SMALL preprocessor flag. alt_sys_init.c:(.text+0x8): undefined reference to `__alt_invalid' collect2: ld returned 1 exit status make: *** Error 1
As the error message suggests, either configure the BSP to use the small drivers so that you don't use interrupts, or go back to SOPC Builder / QSys and connect the JTAG Uart's interrupt port to the Nios CPU.
Thanks Daixiwen. Now I get this error: :rolleyes:
Connected system timestamp not found on target at expected base address.
It looks like the FPGA configuration you have doesn't correspond to the SOPC definition that the BSP used to compile the software. Be sure that you have the right configuration.
You can follow those steps each time you modify the SOPC project:[list][*]save SOPC project and generate it[*]compile the hardware project in Quartus[*]open the Nios IDE, check that it's pointing to the right .sopcinfo file[*]compile the software project[*]upload the correct .sof file to the FPGA (careful! if you are using IP cores without their license, the file could be a *_time_limited.sof instead of the regular one)[*]upload the software[/list]
I just got this warning in Quartus:
Critical Warning: Timing requirements not met
and error in Nios II:
Verify failed between address 0x1100020 and 0x1100177
:confused:
For the riming warning you need to open Timequest and find out the top failing paths to determine what to do.
For the second error, first check that your main memory is indeed at address 0x1100000, and then try to run a memory test on it. But you should fix the timing problem first.
I checked the sram in qsys, it was indeed at address 0x01000000 to 0x011fffff.
In TimeQuest, I found this, but I didn't know what to do:
Clock ______________ Slack __________ End Point TNS
clk_________________-1.224___________-1.596
pll|sd1|pll7|clk[0] ____ 2.057___________0.000
ssram_clk____________4.926___________0.000
tck_________________18.366__________0.000
altera_reserved_tck___45.114__________0.000
:D
There is another report in Timequest that is called "Top Failing Paths". Is will probably be somewhere in the setup summary. Just look up for categories that are in red.
Here is the Top Failing Paths. What should I do? :confused:
http://img715.imageshack.us/img715/6291/timequest.png
I find it strange that you have two different clocks on those paths... Could you describe your clock distribution, and share your sdc constraints files?
There is a PLL with 1 input clock and 2 output clock. I attached the sdc file. Please have a look. :)
From a quick look it seems that your problem comes from the fact that you defined some of the I/O in the "clk" domain when those signals are generated from a different clock in the system, that has a different frequency. You should define all your I/O delays for the flash and SRAM I/O relative to the ssram_clk clock.
I fixed all the failing paths, but Nios II failed to verify sram. :D
Now you should run a memory test.
Are you sure your I/O timing constraints for the SRAM pins match the memory datasheet?
The memory test software also failed to verify sram. This is the first time I constraint the sram, but I think I do it correctly. I can send the project if you want to have a look. :D
Without the hardware it will be difficult to debug the project... Which test is failing exactly? Do you have any error message?
Hello World Small and Memory Test Small both gave this error:
Using cable "USB-Blaster ", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloaded 8KB in 0.1s Verifying 01200020 ( 0%) Verify failed between address 0x1200020 and 0x1201DAF Leaving target processor paused
Address 0x1200020 to 0x1201DAF was sram location. :D
To do a memory test of SRAM you really want to load the test program to internal memory.
Can you tell me specificly how to load program to internal memory? :)
First you need an onchip memory in your system, connected to both the Nios CPU's instruction and data masters. Then in the BSP settings, set all the memory configurations to your on-chip memory. If the memory is small, select the small C option, and enable the compiler optimisations.
Thank you for your guide. I successfully loaded the software to FPGA, and I got flash memory test failed:
-Data bus test failed at bit 0x1
And the sram memory test made the software crashed at this point:
-Data bus test passed -Address bus test passed -Byte and half-word access test passed -Testing each bit in memory device.
I don't know how to fix. :p
