I am doing my first Nios II tutorial from you tube, which is LED blink in QuartusII V. 7.2 on DE2-70 ,Cyclone II EP2C70 FPGA. Developed Nios II system with SOPC buider and able to see the LED blinking on the board. But when i added Cfi_flash memory to the SOPC and trying to run Niosii as hardware , i am getting an error : program failed at offset 1F. Leaving target processor paused. What might be the problem and how do i eliminate this error. Cfi_flash memory address is 0x00800000 What is the address bus width for cfi_flash 22 or 23? (http://www.youtube.com/results?search_query=my+first+nios+ii+tutorial&aq=f)Link Copied
