Yesterday I was able to generate a .hex file for my onchip flash memory contents, but today when I run the mem_init_generate make target it's giving me an error.
Here is the console output:
wsl make mem_init_generate
Info: Building /mnt/e/repos/Vx834_LRF/FPGA/TestBoard/software/Vx834_LRF_bsp/
make --no-print-directory -C /mnt/e/repos/Vx834_LRF/FPGA/TestBoard/software/Vx834_LRF_bsp/
[BSP build complete]
Post-processing to create mem_init/onchip_flash_0.hex...
alt-file-convert.exe -I elf32-littlenios2 -O hex --input=Vx834_LRF.elf --output=mem_init/onchip_flash_0.hex --base=0x00020000 --end=0x0003c7ff --reset=0x00020000 --out-data-width=8 --boot="/mnt/e/intelfpga_lite/19.1/nios2eds/components/altera_nios2/boot_loader_cfi.srec"
Apr 9, 2020 11:41:43 AM - (SEVERE) elf2flash: Read error: File not found: /mnt/e/intelfpga_lite/19.1/nios2eds/components/altera_nios2/boot_loader_cfi.srec
Apr 9, 2020 11:41:43 AM - (SEVERE) elf2flash: Error reading boot copier
Apr 9, 2020 11:41:43 AM - (SEVERE) elf2flash: Error generating Flash file, exiting
nios2-elf-objcopy: 'C:\Users\devin\AppData\Local\Temp\tmp3_iay72c': No such file
Converting Nios II ELF file to HEX file. Appending boot file.
Post-processing to create onchip_flash_0.flash...
elf2flash.exe --input=Vx834_LRF.elf --output=onchip_flash_0.flash --sim_optimize=0 --base=0x00020000 --end=0x0003c7ff --reset=0x00020000 --boot="/mnt/e/intelfpga_lite/19.1/nios2eds/components/altera_nios2/boot_loader_cfi.srec"
make: *** [onchip_flash_0.flash] Error 5
/mnt/e/repos/Vx834_LRF/FPGA/TestBoard/software/Vx834_LRF_bsp/mem_init.mk:359: recipe for target 'onchip_flash_0.flash' failed
elf2flash is throwing an error saying that "boot_loader_cfi.srec" can't be found, but the file exists in the specified directory. If I open wsl and enter the directory as specified, I can see the file just fine.
I googled various permutations of the error message. The only thing I found that was matching was something from ~2009, applicable to the first gen Nios processor, saying you need to run the SOPC Builder, but I don't think this is applicable here.
Any idea what is going on?
-Devin
Hi Devin,
I am facing the same issue.
Did your problem got resolved ?
BRs,
Johnson
Not yet, just started working on something else for a bit to see if I got any replies. Gonna take another crack at it, maybe later today. I'll post if I get any results.
Hi Devin,
Thanks for the reply and hope you have good news to share.
I found a link about how to generate the flash manually by using alt-file-convert.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/embedd...
I tried but not work..
Because I don't know how to use this program...
FYI!
BRs,
Johnson
I tried using the method in the link, by copying the boot_loader_cfi.srec file to my Nios II software directory and running alt-file-convert.exe through the Nios command line. This is the error I received. It seems suspiciously similar to the old error. Unfortunately, the output of the executable is ambiguous as to which file it could not find, the .ELF or the bootloader, although I suspect that it is the bootloader. I tried omitting the --boot option from the executable arguments, and got a different error - "must be str, not NoneType".
If I can't convert my .ELF file to a hex, I'm kind of dead in the water with my design. Can someone else please weigh in on this?
-Devin
Hi Devin,
I tried the link and generate the hex file successfully.
But for unknown reason, my Nios 2 does not boot after programming.
I noticed minor difference between your setting and mine.
Anyway, i attached my command below for your reference,
FYI!
BRs,
Johnson
Hit this error also.
It seems that there is some file path problems between Windows and linux subsystem.
Found out a workaround by making a copy of bootloader_cfi.srec to eclipse workspace directory and making modification to BOOT_LOADER_CFI in bsp mem_init.mk file.
#BOOT_LOADER_CFI ?= $(BOOT_LOADER_PATH)/boot_loader_cfi.srec
BOOT_LOADER_CFI ?= ../boot_loader_cfi.srec
(Nios project and bsp are directly under workspace)
edit: --
alt-file-convert.exe seems to want a windows path for --boot option (in windows machines), as mem_init.mk BOOT_LOADER_CFI modification to windows path removes error:
BOOT_LOADER_CFI ?= "'C:\intelFPGA\19.1\nios2eds\components\altera_nios2\boot_loader_cfi.srec'"
With this modification the mem_init_generate runs and there is a flash hex file which content seems to be correct (real world booting not tested yet)
-Pauli-
Hi @ppauli ,
many thanks for this solution!
I am facing this issue with Quartus Prime Pro 19.3 as well. Your fix seems to work. I did not verified on a target, yet.
Is this issue fixed in newer Versions of Quartus Prime? Is there an official solution provided by Intel?
BR, Dirk
