Hi all,
I've just downloaded Quartus 13Sp1. I'm having a 3 day issue with eclipse and I was hoping the support pack may have provided the solution, unfortunately it did not! The problem is when i compile my project in Eclipse I get the following error. https://www.alteraforum.com/forum/attachment.php?attachmentid=8605 I've searched high and low, tried the linker fix where I added -lm to 'project'\niosII application properties\Linker flags - perhaps I'm doing it wrong. I've examined my code, it compiles when I do not include [ //xxxx ] the lines of code causing the error. I appreciate this may be a stupid question to the more experienced members, but I'm at my wits end with it. Eclipse is quirky so I'm always sure to, save all changes. Then regenerate/clean build and finally build the bsp. And again, clean build and build the project. If I go project properties/C/C++ General/Paths and Symbols - the included directories are shown below https://www.alteraforum.com/forum/attachment.php?attachmentid=8606 The next tab Symbols is populated. A possible issue may be the Libaries and Library Paths tabs are both empty. Source Location conatain folder /'project' The code itself: I have my main.c program and included two header files. The functions causing the issue is contained in a header file. The main.c has include"xxxxx.h" for both header files but I keep getting the errors. The following article seems to be well on the buck but no joy again http://stackoverflow.com/questions/5005363/undefined-reference-to-sin-in-c Perhaps I'm overlooking or doing something wrong, any help or tips would be much appreciated. CianLink Copied
Hi, try : right click on your project, "rebuild index"
Thanks for taking the time to reply.
No joy with that I'm afraid :/- Mark as New
Hello,Did you figure this problem out?
