I'm working with Nios II system and frequently I had to rely on the Nios II output console to debug my application code. Initially when I build the project, the console is working fine. But after some time, the console stops displaying the output.
Sometimes, when I regenerate my BSP and rebuild the project, it's working. Sometimes, I need to reprogram my FPGA and then reopen the project.
I'm curious to know what's wrong as I'm not particularly changing any parameters to get it working.
Kindly help.
I'm sure the issue is not with the code. Just a while ago, the code was working fine, and when I run it again, the Nios output console is not displaying anything now.
Later, I tired creating another Nios II application in Eclipse to have just the Hello_World template. Still the same.
I'm sorry I attached wrong snipshots in the previous reply. Please look at the attached images
