Nios II PS2 Keyboard
In QSYS I added a PS/2 Controller IP Core and wired it in Verilog.
My code:
#include <stdio.h># include <stdlib.h># include "system.h" # include <altera_up_avalon_ps2.h># include <altera_up_ps2_keyboard.h> alt_up_ps2_dev *ps2; KB_CODE_TYPE *decode_mode; alt_u8 buf; char ascii; int main() { ps2 = alt_up_ps2_open_dev("/dev/ps2"); alt_up_ps2_init(ps2); printf("Detected device: %d\n",ps2->device_type); while (1) { decode_scancode(ps2,decode_mode,&buf,&ascii); if (*decode_mode != 6) printf("Decode mode: %d Buffer: 0x%X ASCII: %c\n",*decode_mode,buf,ascii); } return 0; }Decode mode is always 1 or 2, and the buffer is always one byte even if it should be longer. (for example Right Alt key)
Problem solved. Can not execute decode_scan without any delay.
Can you help me?
I have a problem with ps2 keyboard interface.
I used a ps2 controller and used code C in Nios ii for connect to PS2 keyboard
But when I try to connected and detected device by instruction " printf("Detected device: %d\n", ps2->device_type);" then result is:
"Detected device: -1".
what wrong with my project? Please help me.
