12471 Discussions
Nios II Reference Design with DDR2 for Cyclone IV FPGA Development Kit?
Does anyone have a Qsys design with DDR2 instantiated and working for the Cyclone IV FPGA Development Kit?
I tried adding a DDR2 controller to the provided BUP design in Qsys with what appeared to be the correct parameters; however the code would not compile in Quartus due to some strange errors with the memory IP (i.e. outputs driving multiple nets???). If someone has a working Qsys project with the DDR controller(s) already hooked up and working on this board, it would save a bunch of debugging time. A design *with Nios* would be ideal but not necessary as I can always easily add the processor and other peripherals to a working system. In fact, any project for this board with DDR2 would be most helpful.
Thank you.
