Recently I had to start working on a workstation with CentOS 6.5 as operating system. I installed the Quartus Software, version 11.1, but the Eclipse tools for Nios II just do not open. Then I installed Quartus 13.1, but problem still persists.
Here is the output I get when executing the eclipse-nios2 -debug command from terminal:Start VM: /opt/altera/11.1/quartus//linux/jre/bin/java
-Dosgi.requiredJavaVersion=1.5
-XX:MaxPermSize=256m
-Xms40m
-Xmx384m
-jar /opt/altera/11.1/nios2eds/bin/eclipse_nios2//plugins/org.eclipse.equinox.launcher_1.1.0.v20100507.jar
-os linux
-ws gtk
-arch x86
-showsplash
-launcher /opt/altera/11.1/nios2eds/bin/eclipse_nios2/eclipse
-name Eclipse
--launcher.library /opt/altera/11.1/nios2eds/bin/eclipse_nios2//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.1.1.R36x_v20100810/eclipse_1309.so
-startup /opt/altera/11.1/nios2eds/bin/eclipse_nios2//plugins/org.eclipse.equinox.launcher_1.1.0.v20100507.jar
-exitdata 4d0054
-product org.eclipse.epp.package.cpp.product
-Debug
-perspective com.altera.sbtgui.ui.cPerspective
-vm /opt/altera/11.1/quartus//linux/jre/bin/java
-vmargs
-Xms40m
-Xmx384m
Install location:
file:/opt/altera/11.1/nios2eds/bin/eclipse_nios2/
Configuration file:
file:/opt/altera/11.1/nios2eds/bin/eclipse_nios2/configuration/config.ini loaded
Configuration location:
Framework located:
file:/opt/altera/11.1/nios2eds/bin/eclipse_nios2/plugins/org.eclipse.osgi_3.6.1.R36x_v20100806.jar
Framework classpath:
Splash location:
/opt/altera/11.1/nios2eds/bin/eclipse_nios2/plugins/org.eclipse.platform_3.6.1.v201009090800/splash.bmp
Debug options:
file:/home/cramos/.options not found
Time to load bundles: 5
Starting application: 1059
After the last line, the application never ever starts. On the other hand, when executing the nios2-ide command, here is what I get: /opt/altera/11.1/nios2eds/bin/nios2-ide: line 17: /opt/altera/11.1/nios2eds/bin/eclipse/nios2-ide: No such file or directory
/opt/altera/11.1/nios2eds/bin/nios2-ide: line 17: exec: /opt/altera/11.1/nios2eds/bin/eclipse/nios2-ide: cannot execute: No such file or directory
However, that directory does not exists (I attach an image of the contents of the Nios II directory). https://www.alteraforum.com/forum/attachment.php?attachmentid=8487 I cannot seem to get the Nios II tools running on Linux, and there is no other error message to track down. If further information about the work environment is needed, I will gladly post it here. Any help would be greatly appreciated. Thanks in advance.
--- Quote Start --- Recently I had to start working on a workstation with CentOS 6.5 as operating system. I installed the Quartus Software, version 11.1, but the Eclipse tools for Nios II just do not open. Then I installed Quartus 13.1, but problem still persists. Here is the output I get when executing the eclipse-nios2 -debug command from terminal:
-Xms40m
-Xmx384m
-os linux
-ws gtk
-arch x86
-showsplash
-name Eclipse
-exitdata 4d0054
-Debug
-vmargs
-Xms40m
-Xmx384m
Install location:
Configuration file:
Framework located:
Splash location:
Debug options:
However, that directory does not exists (I attach an image of the contents of the Nios II directory). https://www.alteraforum.com/forum/attachment.php?attachmentid=8487 I cannot seem to get the Nios II tools running on Linux, and there is no other error message to track down. If further information about the work environment is needed, I will gladly post it here. Any help would be greatly appreciated. Thanks in advance. --- Quote End --- -------------------------------------------------------------------------------------------- Most problems that I hadwith Centos 6.5 linux 64-bit Quartus 12 nios2eds installations are missing 32-bit (i686) libraries... /usr/lib/libmissings ------------------------------------------------------------------------------------- use yum list whatever to see whatever is installed and use yum install whatever-is-missing to install the missing i686 libraries. e.g. yum list glibc libXext libX11 libXau libXdmcp freetype fontconfig expat I did: yum install expat.i686 yum install fontconfig.i686 yum install freetype.i686 yum install libX11.i686 ---------------------------------------------- ok... I saw the Quartus flash screen but sopc-builder can't start:( ---------------------------------------------- For me I ran /opt/altera/12.1/quartus/sopc_builder/bin/sopc_builder to see what 32-bit libraries are missing, I discovered libXtst.so is missing.. so yum again yum install libXtst.i686 ---------------------------------------------- ok... saw the sopc builder flash screen but eclipse can't start :( I got the idea from here: http://aalonso.wordpress.com/2009/07/02/altera-quartus-2-on-fedora-11/ ---------------------------------------------- yum install gtk2.i686 // need for eclipse yum install libcanberra-gtk2.i686 // don't need ---------------------------------------------- ----------- for usb blaster permission create file /etc/udev/rules.d/51-usbblaster.rules with content # USB-Blaster BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666" BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6002", MODE="0666" BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6003", MODE="0666" :)
I had exactly the described problem.
yum install gtk2.i686 seems to have fixed it. Thanks! Every tools seems to require some hidden i686 feature.For more complete information about compiler optimizations, see our Optimization Notice.
