Nios II UART Troubles
Honored Contributor I
OK, I am porting some code from Nios 1 to Nios 2 and I am stuck on the UART code. Here is the original code:
char poll_uart_rx( void ) {     int i;     i = nr_uart_rxchar( na_uart_0 );     if( i == -1 )  return( 0 );     else  return( (char) i ); }
The new Nios 2 documentation says to use getchar() or getc(). These both seem to be blocking reads. I need a non-blocking read. Looking through "altera_avalon_uart.c" I found that 'alt_avalon_uart_read' supports non-blocking reads, but what newlib call do I make to get a non-blocking read? Thanks
I open device uart in non blocking mode:
static int fdterm; // FILEDESCRIPTOR RETURNED BY OPEN
fdterm = open("/dev/uart1", O_RDWR | O_NONBLOCK | O_NOCTTY);
reading is done by
res=read(fdterm,uart1_tempbuff,sizeof(uart1_tempbuff)-1);
if(res>0) {
... we have received some bytes
