Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Nios II flash programmer problem
I have a problem with the Nios II flash programmer.
I created a project with the Quartus 10 SOPC builder starting from the reference design, triple-speed Ethernet. With Quartus 10 could program the nios. Moving to version 11 I have the following problem with the NIOS II flash programmer
Erase failed at offset 800000
Leaving target processor paused
Error code: 1 for command ...
I'm using the STRATIX IV - EP4SGX230KF40C2
11.0的USB-Blaster驱动有问题,换以前的版本即可。
The driver of usb-blaster v11.0 can not work normally, try an old version to fix the problem.
