Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Nios II functionality not showing up in Eclipse.
I just installed QII-SE v11.0 and now the Nios II functionality is not showing up in Eclipse. For instance, when I click on the "File>New" menu, I on get a "New Project..." option, not the usual "New Nios II Project and BSP from Template..." that I had with v10.1.
When I click on "Installation Details" on the Eclipse "Help" dialog box, it shows:
Nios II Software Build Tools & System Console 11.0.0.157 com.altera.sbtgui.integration.feature.feature.group
Any suggestions???
I just re-installed the entire Quartus II 11.0 SE package and now Eclipse works properly with all the Nios II functionality.
hey.. i'm wondering how you had the NIOS II functionality... I'm trying to search for New NIOS II Project and BSP from Template but it doesn't have it.. so what did you do?
When installing the tools I recommend closing any anti-virus programs and run the installer as the administrator. AV programs shouldn't be causing the problems with the installer like they used to but it couldn't hurt to close them down temporarily.
