Nios II memory problem
I am new to NIOS II, i am following the hardware tutorial provided by Altera to make basic Nios system, when i make the complete system in Qsys as instructed following errors are encountered when i click generate
Error: onchip_mem: wrong# args: should be "sub_quartus_synth NAME"
while executing
"sub_quartus_synth nios ii_onchip_mem"
Error: Generation stopped, 4 or more modules remaining
Error: ip-generate failed with exit code 1: 2 Errors, 0 Warnings
I am short on time and desperate for help. Thanks in advance
Are you prehaps using space in the name of component?
Although i got the problem fixed, by first making the project in Quartus and then making its Qsys file, but tutotrial said to start with q sys and then make the project in quartus! thanks
