Hello Everybody !
I'm trying to implement a Nios II Qsys Design with enable ECC. I'm using:- a fast Nios II (Gen2 Processor);
- an On-Chip (RAM) memory with its ECC Parameter enable;
- Others IP like JTAG, PIO, ....
Nobody from Altera have an answer?
I assume that you checked the "Extend the data width to support ECC bits" or something like that depending on which version of Quartus.
The above option is only can be used when you have Tightly coupled instruction/data masters connected to it. If you want to connect to instruction_master and data_master, you need to uncheck the option.
Topic Options
