Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Nios communicate with external dsp(dual port ram inside)
Recently I want to use Nios communicate with external device.
The device is a RT-Ethernet chip,which have a ARM and dpram in ti.So FPGA and ARM will access the shared dpram.
I don't know what should I add in Nios to implement this function. I'm not sure that 'avalon tristate bridge' can be used.
Thank you very much!
I have write an interface for nios and external ram.
Could someone give me some instructions?Thanks a lot!
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity TPS_Bridge is
port (
-- global signals (clock and reset)
clk : in STD_LOGIC;
resetn : in STD_LOGIC;
-- Avalon-MM slave generic signals
-- note that there is no address as this component
-- only has 1 read and write register
chipselect : in STD_LOGIC;
address : in STD_LOGIC_VECTOR (15 DOWNTO 0);
byteenable : in STD_LOGIC_VECTOR(1 downto 0);
-- Avalon write interface
avalon_writen : in STD_LOGIC;
writedata : in STD_LOGIC_VECTOR (15 downto 0);
waitrequest : out STD_LOGIC;
-- Avalon read interface
avalon_readn : in STD_LOGIC;
readdata : out STD_LOGIC_VECTOR (15 downto 0);
--TPS-1 DPRAM interface
TPS_data : INOUT STD_LOGIC_VECTOR (15 DOWNTO 0);
TPS_addr : OUT STD_LOGIC_VECTOR (15 DOWNTO 0);
TPS_CS : OUT STD_LOGIC;
TPS_RD : OUT STD_LOGIC;
TPS_WR : OUT STD_LOGIC;
TPS_RDY : IN STD_LOGIC;
TPS_BYTE_SEL_LOW : OUT STD_LOGIC;
TPS_BYTE_SEL_HIGH : OUT STD_LOGIC
end entity TPS_Bridge;
architecture InterfaceLogic of TPS_Bridge is
begin
TPS_addr <= address(15 DOWNTO 0);
TPS_RD <= avalon_readn;
TPS_WR <= avalon_writen and byteenable(0) and byteenable(1);
TPS_CS <= chipselect;
TPS_BYTE_SEL_LOW <= byteenable(0);
TPS_BYTE_SEL_HIGH <= byteenable(1);
waitrequest <= TPS_RDY;
tristate_control: process(TPS_RDY,avalon_writen,chipselect,avalon_readn)
begin
if (avalon_writen = '0' and chipselect = '0' and TPS_RDY = '0')then
TPS_data(15 DOWNTO 0) <= writedata(15 DOWNTO 0);
elsif(avalon_readn = '0' and chipselect = '0' and TPS_RDY = '0')then
readdata(15 DOWNTO 0) <= TPS_data(15 DOWNTO 0);
end if;
end process tristate_control;
end architecture InterfaceLogic;
