Recently I want to use Nios communicate with external device.
The device is a RT-Ethernet chip,which have a ARM and dpram in ti.So FPGA and ARM will access the shared dpram. I don't know what should I add in Nios to implement this function. I'm not sure that 'avalon tristate bridge' can be used. Thank you very much!Link Copied
I have write an interface for nios and external ram.
Could someone give me some instructions?Thanks a lot! library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity TPS_Bridge is port ( -- global signals (clock and reset) clk : in STD_LOGIC; resetn : in STD_LOGIC; -- Avalon-MM slave generic signals -- note that there is no address as this component -- only has 1 read and write register chipselect : in STD_LOGIC; address : in STD_LOGIC_VECTOR (15 DOWNTO 0); byteenable : in STD_LOGIC_VECTOR(1 downto 0); -- Avalon write interface avalon_writen : in STD_LOGIC; writedata : in STD_LOGIC_VECTOR (15 downto 0); waitrequest : out STD_LOGIC; -- Avalon read interface avalon_readn : in STD_LOGIC; readdata : out STD_LOGIC_VECTOR (15 downto 0); --TPS-1 DPRAM interface TPS_data : INOUT STD_LOGIC_VECTOR (15 DOWNTO 0); TPS_addr : OUT STD_LOGIC_VECTOR (15 DOWNTO 0); TPS_CS : OUT STD_LOGIC; TPS_RD : OUT STD_LOGIC; TPS_WR : OUT STD_LOGIC; TPS_RDY : IN STD_LOGIC; TPS_BYTE_SEL_LOW : OUT STD_LOGIC; TPS_BYTE_SEL_HIGH : OUT STD_LOGIC ); end entity TPS_Bridge; architecture InterfaceLogic of TPS_Bridge is begin TPS_addr <= address(15 DOWNTO 0); TPS_RD <= avalon_readn; TPS_WR <= avalon_writen and byteenable(0) and byteenable(1); TPS_CS <= chipselect; TPS_BYTE_SEL_LOW <= byteenable(0); TPS_BYTE_SEL_HIGH <= byteenable(1); waitrequest <= TPS_RDY; tristate_control: process(TPS_RDY,avalon_writen,chipselect,avalon_readn) begin if (avalon_writen = '0' and chipselect = '0' and TPS_RDY = '0')then TPS_data(15 DOWNTO 0) <= writedata(15 DOWNTO 0); elsif(avalon_readn = '0' and chipselect = '0' and TPS_RDY = '0')then readdata(15 DOWNTO 0) <= TPS_data(15 DOWNTO 0); end if; end process tristate_control; end architecture InterfaceLogic;
Topic Options
