Nios interrutions
I use quartus II 4.00 and SOPC builder 4.00 to build a NIOS system on a Stratix II board.
I enabled the support for external interruptions, add a user defined IP connected via the provided avalon ahb bridge.
Everything is ok.
Then I try to use the interruption of the bridge, everything on the wire is ok until the data_master_irq gets high. The iq number is ok, NIOS makes a couple of instructions more and then stops on a strange adress (totallly out of the memory map). but it doesn't fetch the ISR code indeed.
The soft uses nr-installusr and is exactly the same as the examples provided.
I tried whithout any soft isr and initialisation to see if i get the famous message ... but nothing.
How can I be sure of what is done by the compiler, is there any restriction that I don't respect ? thanks for all your help and experience about those interrupts on NIOS systems.
Sincerely
Julien Chevalier
Humm....
For fun... Try assigning the IRQ you are having a problem with to a different number in SOPC Builder. Regenerate, do another Place and route and see what happens then.
Seems kind of strange that you are using an avalon to AHB bridge.
hbutler97
Did you get this all figured out?
Please tell us.
