I'm using Q13.1 and run Nios from EPCQ (EPCS/EPCQx1 Serial Flash Controller installed in Qsys). Nios binary copied from EPCQ to DDR after power up. I generate jic file using Convert Programming File tool and everything works fine. So all offsets and setting is ok. But if I try to enable encryption in SOF properties, NIOS application not starting after power up. FPGA fabric still starts successfully. What might be reasone of this?
Are you using the hex file as on-chip memory initialization file or separated file ? if the first option then I suggest to make it separated from the .sof
Hi, thanks for answer. I'm using hex file, which is generated like this:
#Create a flash image of your FPGA configuration file
sof2flash --input=hw.sof --output=hw.flash --epcq --verbose
#Note: We are using --epcq instead of --epcs here for EPCQ devices
#Create a flash image of your NIOS II .elf file
elf2flash --input=sw.elf --output=sw.flash --epcs --after=hw.flash –verbose
#Create the .hex image of your Nios II software
nios2-elf-objcopy --input-target srec --output-target ihexsw.flash sw.hex
Topic Options
