12473 Discussions
Nios using onchip memory resets continuously
I am using a small footprint EP4CE6 FPGA with NIOSII built using 20KB on chip memory. Using Eclipse IDE I built the "small hello world" example as a starting point. My problem is that when I add anything more than a simple alt_printf statement, the cpu continuously resets itself.
I think it may be because I am not setting up the complier correctly. The instructions refer to the old NIOS IDE. I would like to know how to set these using the ECLIPSE IDE.
- Define the preprocessor option ALT_NO_INSTRUCTION_EMULATION
- Set Periodic system timer and Timestamp timer to none
- Set Max file descriptors to 4
- Uncheck Clean exit (flush buffers)
and any other settings you think is necessary to run NIOS CPU with on-chip memory only.
nathan
How large is your onchip memory? I've seen this happen when I had too small of memory.
--- Quote Start ---
--- Quote End ---
20KB. I generated Qsys system as per the NiosII hardware Development tutorial.
