Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Nios won't boot uCLinux with data cache greater than 8k
We are running uCLinux (non-mmu community version)on a NIOS II SOPC 11.0 system, on our own hardware, Booting from EPCS copying the operating system and application code from EPCS to the external SDRAM. Once copied the system then runs from SDRAM.
In a bid to speed up the Ethernet operation we have experimented increasing the size of the instruction and data caches in the NIOS. This has given us massive improvements with each increase in cache.
We now have the instruction cache set to 64K and have managed to increase the data cache to 8K.
The problem is. If we try and increase the data cache beyond 8K the system will not boot.
Please does anyone have any ideas on things to try?
I have the same problem...
Can an Guru help us ?
I once heard that for some queer write-back reason greater (data) cache size is not supported. Maybe you can find the appropriate thread here or in the NIOS-develop mailing list, or maybe in an Altera hardware forum.
-Michael
Watch out for the reply from our Ian Abbott, He has found the problem
I think I've found the solution. In arch/nios2/mm/memory.c, change the icache_push function to flush the data cache before invalidating the instruction cache. This can be done by inserting the line: cache_invalidate_data(vaddr, len); so the whole function is as follows:
void icache_push(unsigned long vaddr, int len) { cache_invalidate_data(vaddr, len); cache_invalidate_inst(vaddr, len); }
(Note that cache_invalidate_data() is a bit of a misnomer as it actually writes dirty cache lines to memory before invalidating them. Also, I'm using the 'test-nios2' branch of Thomas Chou's git repository.)
The reason this is needed is that load_flat_file() in fs/binfmt_flat.c (which is responsible for loading executables in FLAT or ZFLAT format) calls flush_icache_range() after loading the executable into memory. The NiosII implementation of flush_icache_range() in include/asm-nios2/cacheflush.h) just calls the icache_push() function described above. However, with the old version of icache_push() there may still be dirty data cache lines that have not yet been written to memory. If the CPU reads instructions from these memory addresses before the data cache lines have been flushed, it will be reading invalid (stale) instructions.
flush_icache_range() is also called when loading kernel modules.
Presumably with an 8K or less data cache it's only been working by chance so far!
