12602 Discussions
Nios2 Crashes when SDRAM is shared
I'm sharing my SDRAM between a Nios2 processor and a Avalon MM Master Writer that is performing write operation on the SDRAM.
The Nios2 processor is working fine until I perform a write operation which causes the processor to stop working (no more instruction seems to be performed any more).
How can I make it work ?
Nemesys
At a guess your Avalon master is buggy - maybe not detecting the end of the write (or something) and locking the other masters out of the SDRAM.
signaltap might be informative.
The Avalon MM Master Writer is an implementation of the Avalon MM template from Altera.
I figured I was writing in outside the SDRAM address map. Now it works properly.
