12471 Discussions
NiosII, No ELF file path has been selected
Hello everyone ,
I written a PID controller in NiosII, hello_world_small,yesterday, and everyting was OK.
I change some codes just now, and I get message :
Errors(3 items)
address 0xbfdc of PID1.elf section,'bss' is not withinregion'onchip_memory'
address 0xbdfc of PID1.elf section ,'onchip_memory' is not within region'onchip_memory'
make:***[PID1.elf]Error 1
And I check the Run configurations,the message is :
No ELF file path has been selected.
What's going on?:( How to generate the ELF file?:confused:
Could you please give a Screenshot of your QSYS-System and from the configuration of the NIOS inside the QSYS-System?
I think there could be the Problem.
If not, please send a Screenshot of the BSP-Editor (Linker-Script-Tab).
If your Project is error free, then an elf-File will be created and could be seen under Run Configurations.
Can you pleas also attach the configuration of the NIOS to see the reset and exception vectors?
I was failed to upload the screenshot.
Reset Vector
Reset vector memory: onchip_memory.s1
Reset vector offset: 0x00000000
Reset vector: 0x00004000
Exception Vector
Exception vector memory: onchip_memory.s1
Exception vector offset: 0x00000020
Exception vector: 0x00004020
Seems to be everything okay.
Could you please try make a completely new SW-Project. Sometimes the NIOS EDS is hanging on some old settings...
It seems that the only solution is to make a new project
so it is solved with a new SW-Project?
New NiosII application and BSP from template.
