Hi there,
i do a migration to NiosII , for now nothing problem except one., why when i use objcopy to transform and .out file to Binary the bin files have an increasead size (it is filled with 1Mb of 00! ) , instead the same command on Nios I built an correct binary file? Thank's a lot JjLeto.Link Copied
Hi JjLeto,
Has your memory map changed? Or have you moved your code to flash? You probably have a large "hole" between a few of your sections that's being filled with 0. Check your .out file with objdump: $ nios2-elf-objdump -h file.out You may need to provide a few load addresses in your linker script. Regards, --Scott- Mark as New
Thank's now i check,
i using then default script.. Bye- Mark as New
Thank's Again i fix it
Bye- Mark as New
I have run into the same problem. When I take the flash.flash file and run it thru my srec to flash utility the resulting binary is about half the size. When I run objdump on the .elf, stripping all symbols and debug, it is still much larger than the flash.flash file.
What command parameters does the IDE use to produce the .flash file from the .elf, and where does the build message output go anyway? thanks- Mark as New
I see that if I do a command line make, I get to see the output.
elf2flash is used by the IDE to produce the .flash file Which of the elf2x or flash2x can be used to get the binary instead?- Mark as New
elf2flash produces a .flash...but if you'll open the file you'll notice that its really a Motorola s-record.
This can be converted to binary pretty easily via some scripting, google --> freeware download, or try out nios-convert (open an SDK shell and type nios-convert). I cannot remember if nios-convert supports binary but it converts between several other formats.- Mark as New
nios-convert does not appear to output plain binary format. The only altera tool that comes close is the quartus Convert Programming Files dialog, which can do sof to just about anything including rbf. It only seems to take sof as input so it is no help for srec or elf to bin. BTW, can the quartus converter be invoked from the command line?
Kinda strange that there is no altera sw tool that will produce a plain binary file as output. It is the most common and necessary format after all. Must be one of those 'branding' things;0- Mark as New
Branding?.. no... I think its been that there has been no need for it to make our tools work as desired.
The beauty of our tools is that its all open-source though; nios-convert calls format_conversion_utils.pm (located within the quartus installation); you could just add the necessary functionality to it and share it here for all to see ;-) Also I was serious about google -- while doing some recent work I came across an s-record to binary converter with 2-3 minutes of searching which I just downloaded and used for my needs at the time.... On your question about quartus conversions: yes, all (I believe) Quartus utilities are scriptable and available via the command line. quartus_cpf is "convert programming files".- Mark as New
Hi jjletodoc
I meet the same problem.But I can't find the link script file. It is in the syslib folder? Thank you .- Mark as New
Hi
The files is nios_build.ld in include directory of sdk i 've removed the line of : "Stabs debugging sections." and the binary go to normal size..- Mark as New
Sorry Errata Corrige
i Remove the LINES after the Comment Stabs debugging sections..- Subscribe to RSS Feed
